Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Jb4 ISO 31
Reply
      08-19-2015, 09:56 PM   #1
PR3C1SN
Platinum Member
PR3C1SN's Avatar
Drives: F06 M6, E91 328i
Jb4 ISO 31
After I updated my firmware, my bov would go off every shift. Didn't have this problem before.. My cars an automatic by the way. Any else had this issue?
      08-19-2015, 09:59 PM   #2
mojobmw_e90
Drives: 2014 E63S
This is normal. Since the Throttle is more sensitive, the wastegates close sooner hence better response.. Better response means more air in system and the bov has to work work when pedal is released
      08-19-2015, 11:40 PM   #3
PR3C1SN
Platinum Member
PR3C1SN's Avatar
Well, that would be true if it was for a 6 speed MT. I have an automatic so it shouldn't be going off since throttle isn't closing
      08-20-2015, 06:20 AM   #4
mojobmw_e90
Drives: 2014 E63S
I'm a automatic as well and I hear it. But mine isn't often, it's more only past a certain amount of throttle.. U might be having surging issues with your menu 11 and 12.9 what do you have them set at
      08-20-2015, 09:23 AM   #5
Antetokounmpo
Antetokounmpo's Avatar
Drives: E90 6MT FBO; '18 F150 Platinum
What did you set menu 11 to?
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      08-20-2015, 12:23 PM   #6
ilicboris
ilicboris's Avatar
80
Drives: 2009 E90 335xi
I noticed this as well. Menu 11 set at 2000 is more noticeable than 1000 was. I didn't like 3000 at all.
      08-20-2015, 07:57 PM   #7
MasterWang
Drives: F06 M6
Automatic with Alpina trans flash here. 11 is set to 1000 and I haven't had that BOV going off during shift problem.
      08-20-2015, 08:29 PM   #8
Antetokounmpo
I tried 1000 and wasn't a fan. Initial tip in was too aggressive for my liking. It also made my takeoffs jerky since I have a MT and was so used to the old response. I put it back to 500, the same as <30 versions. 2000 must be stupid aggressive, not to mention 5000.
      08-21-2015, 12:52 AM   #9
ilicboris
ilicboris's Avatar
80
2000 is pretty jumpy. 3000 I didn't like at all. I have yet to try anything higher, but I do like this new update.
Reply
