Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > E91 maximum rear tire width question
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
Reply
      09-14-2010, 09:23 AM   #1
m3x
Drives: BMW 335d Touring
Hi all,
just registered to get some help with my E91 335d Touring (wagon) -08.
I am planning to buy new wheels and tires but does anyone have any experience with fitting a 275/30-R19 rear tire on your E91? The reason for asking is that while 265 will not rub it does look a little stretched on a 9.5" wheel (at least Falken FK452 does, which my buddy's got fitted on his E91). Please state what offset you have also please.
//JP
      09-14-2010, 01:13 PM   #2
m3x
Please forgive a forum newbie.. Can a mod move this to the tire section.
      09-14-2010, 07:30 PM   #3
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2224
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
From what I remember, E91 rear fenders are the same as E90 fenders. If you are currently running a 265 with some room on the FK's, you should be able to run a 275 without a problem.
-Charles@VMRWheels
      09-14-2010, 08:44 PM   #4
Atsnow
Atsnow's Avatar
92
Drives: E92 335xi, 2010 Boxster S
Originally Posted by m3x View Post
Hi all,
//JP
I had tried my old Breytons on my friends E91 and fitments was exactly the same as my E90
they where 19X9.5 ET35 with General UHPs 275/35/19 he had room to spare compared to me (I was on ZSP suspension) and could have ran a 285 on this tire
      09-15-2010, 02:05 AM   #5
m3x
Charles@vmrwheels: it so happens that I am currently looking at VMR V718 hyper silver wheels which I figure would contrast nicely with the sparkling graphite/shadow line color scheme of my car. Am I right that ET33 in the rear and ET35 is the "standard" E9x offset?
My buddy who's got the 265mm FK's fitted is using a 19x9.5 ET35 wheel in the rear and it is quite a tight fit. So if I use ETT33 it will be even tighter, but I notice that V718 is also available as ET45. Would that work on my E91 you think? I forgot to mention that it's got the standard M-sport package if that changes anything.
Oh, and also, am I correct in assuming that TPMS-sensors are only found on cars in USA?
jackb: that's interesting! was the tire completely worn so that's why it fit so easily?
Very thankful for the insight!
      09-15-2010, 07:06 AM   #6
Atsnow
Atsnow's Avatar
92
No tires where brand new,
here's a few pictures when they where just installed
      09-15-2010, 07:24 AM   #7
m3x
jackb: that looks allright on the pic! No rubbing at all with back seat passengers?
      09-15-2010, 01:10 PM   #8
remmib
remmib's Avatar
Norway
1643
Drives: 2013 F10 520d M-Sport
I think you should go with 275/30/19 if you wants wide tires and are planning to go with 19x9.5 ET33 in the rear.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      09-15-2010, 05:24 PM   #9
VMRWheels
VMRWheels's Avatar
2224
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Yes you are right. 19x8.5 +35 front and 19x9.5 +33 rear.
9.5 +33 would work perfectly fine and will be flush in the rear. Sport height will still be a direct bolt-on fitment and will not require any modifications to the car.
TPMS is only required for vehicles equipped with it in the U.S.
Here are some V718 photos for you.
-Charles@VMRWheels
Reply
Tags
tire size
