The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Interesting code and issue
Reply
      08-17-2015, 09:39 PM   #1
335iNavyGuy
Drives: 07 N54 E92
So i recently got a code,
2DED and
2ABD
30FF
So the first code is a low power which can trigger the cars anti theft programming aka if BMW shuts down the car..
Which is basically what it felt like.
the car just lost all power and stalled out right to 0 rpm.
took like 6 tries but finally started back up and would misfire under high accel.
any ideas? lol
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV
BBS Lm reps - AFE dual cone intake
      08-18-2015, 12:45 AM   #2
jin
New Zealand
82
Drives: 2007 E90 335i
I got the 2DED code along with 30FF when I went WOT with a tune. Car didnt stall just reduced power until code was cleared. In my case it was a vacuum leak.
      08-18-2015, 01:01 AM   #3
ferocity02
Drives: 2013 135is
2ded has to do with something draining your battery when the car is off. I get this code occasionally, figured it was my dying battery or something I'm leaving plugged in but it's never caused issues, it will not cause an SES light. So the 30ff might be the once causing your limp mode
      08-18-2015, 01:15 AM   #4
Bimmer 808
MT or bust!
Drives: 2010 E90 335i M Sport, 6MT
2020 X3 M40i  [0.00]
2015 M235i  [0.00]
2006 330i  [0.00]
2010 335i  [0.00]
i get 2DED whenever i forget and leave my access port or OBD tool plugged in for some time. it triggers a code if there is a measurable drain on the battery.
2010 E90 335i M Sport, MT - BMW PE; VRSF 7in HD; RB PCV; VRSF CP; Turbosmart KPB BOV; M3 Cowl; VRSF Cerakote DPs; Carly coding; ECS Scoops; Ziza interior LEDs; Fuel-It! Bucketless; Diff lock down brace V2; MHD E60 Map from BQ; Mishimoto OCC; Fuel-It! Ethanol Sensor; Apex 18x9 ARC-8's; StopTech slotted rotors; HPS pads; ECS brake lines; MMP turbos, inlets, outlets; 034 mounts; Kumho PS31s; BimmerLife coils
      08-20-2015, 01:50 PM   #5
mirkwo0dforest
Drives: 2007 335i Coupe 6MT Sport/Prem
2DED, that's kinda funny for dead battery, haha!
      08-20-2015, 05:50 PM   #6
335iNavyGuy
Drives: 07 N54 E92
My battery was fine though.. idk but i do see the humor.
07 E92
Reply
