BMW 3-Series (E90 E92) Forum
N54 small air filters on inlets
| 01-20-2019, 03:05 PM | #23 | |
![]() 74
Rep 202
![]() The wgdc is around 45 where it was around 65 in a similar map with just stock intake... |
| 01-20-2019, 04:57 PM | #24 |
![]() ![]() ![]() ![]() 653
Rep 779
Find it really hard to believe venting those dropped DC by 1/3. Didn't fix any boost leaks, clean filter, etc. at the same time? Logs of the same map at 65%?
You've also broken the vacuum that makes the snorkel/ambient supply function, so expect some higher IATs, especially when summer hits. |
| 01-20-2019, 06:03 PM | #25 | |
Rep 2,235
335i e92 TPC 19Ts
| 01-21-2019, 12:47 AM | #26 | |
![]() 74
Rep 202
WGDC a lot lower compared to an E50 map that has almost the same boost levels at high rpm, around 14 psi. It looks good enough for me an not too much in your face if I get pulled over, it sounds good and the car drives hard so for now good enough for me. |
| 01-21-2019, 01:52 AM | #27 |
![]() 74
Rep 202
I will do the test and replace the 2 small airfilters and cap off the holes and do some more logging and report back.
| 01-21-2019, 03:37 AM | #28 |
![]() 74
Rep 202
After looking at more logs I think you may be right about the big difference being too optimistic. Where I got the big difference from: this first comparison is the latest setup with V8 E30 and the K&N + extra airfilters compared to the worst log with stock airbox and filter V8 E50 but around the same boost level, 3rd gear:
![]() ![]() After this last log I did replace my boost solenoids and vacuum line next to my oil filter because I suspected a leak. After that I have logs from around the same boost level, also 3rd gear and it does show about 8-10% more wgdc... Maybe that's more realistic. ![]() ![]() Conclusion, next test is to take off the small filters and cap off the holes, do some datalogging with the same setup airbox and K&N drop in filter and compare those 2 before making any more statements ![]()
2007 BMW E92 335i 6MT lightweight - OS GIKEN Superlock LSD - FBO STAGE 2+ ETHANOL - TRACK/DRIFT/NÜRBURGRING Last edited by Jerain; 01-21-2019 at 03:47 AM.. |
Sgop335745.00 |
| 01-21-2019, 11:23 AM | #29 |
Rep 779
Shouldn't see much change even removing the entire airbox and there are things in tuning and the car that can effect DC without really moving boost too much (including environment changes), but the BCS and tune change was probably it. Thanks for clearing that up.
I figured if you were going to bother buying a Z4 lid, you wanted to keep it closed. Venting the intake side undoes that and pulls air in from under the hood. You'll still get the balance it can't flow from the snorkel, so may not be quite as bad as DCI, but given enough run time, will likely see higher IATs. |
| 01-21-2019, 04:12 PM | #30 | |
![]() 74
Rep 202
But in springtime when the roads will be better I will do back to back testing on the same maps and report back. |
| 01-26-2019, 02:37 AM | #31 |
![]() 74
Rep 202
So after doing another test but now with the small air filter off and capping off the two holes on the inlets (so just stock intake with K&N drop-in and airscoops). First off the IAT were a bit lower, about 6-7F less at the end of 4th gear (and the outside temp are almost freezing over here).
Also the WGDC bank 1% was exactly the same, around 47% max. Also noticed that with the so called DIY BOV mod (stock DV vent to atmosphere) you lose a bit of boost in the first second(s) of WOT, so in the log clearly shows the first RPM not as easy reaching boost target. Normally that's not really a problem because the 2 stock DV vent to inlets itself improving the aircharge. Now they operate a bit slow and that first boost is lost in the engine bay. You can even hear that first part after WOT they lose some boost. Also the whp in virtual dyno are around 450whp so the same as the previous average VDs with the small filters. Conclusion: If you want the lowest IAT (not really a problem if you have a really big intercooler), you want the best throttle response and spool up in low rpm, keep stock DV and intake. For me as a Nurburgring driver and drifter, the low rpm torque and throttle response are more important than those few possible gained whp in the really high rev range. Does anyone has real world experience with the Turbosmart DVs? Seems in testing they respond quicker and hold boost better than the stock DVs?
2007 BMW E92 335i 6MT lightweight - OS GIKEN Superlock LSD - FBO STAGE 2+ ETHANOL - TRACK/DRIFT/NÜRBURGRING |
| 01-26-2019, 09:37 PM | #32 | |
Rep 2,235
will try to post a pic.
335i e92 TPC 19Ts
| 01-27-2019, 06:21 AM | #33 | |
![]() 74
Rep 202
So I bought 2 almost new stock dv's from a guy who switched to BOV cp, because I cut up my original stock dv's (with 150k miles on them) these new ones have just 20000km, he has a bill for them. I see in your signature you have a homemade tune, but when I open your datazap it doesn't seem to have high boost or timing, I can recommend you V8 E30 or E50 MHD, it targets around 18.5 and tapers to around 16psi and has timing around 13 to 12, great power on those maps as you can see in my last virtual dyno, around 450-460whp!
| 01-27-2019, 08:21 AM | #34 | |
Rep 2,235
335i e92 TPC 19Ts
| 01-29-2019, 05:07 PM | #35 | |
Rep 513
Drives: 2008 335i
If you approach this as a max air flow capacity problem, and you think your DCI's air flow capacity is being maxed out then yes, two extra intakes would help to alleviate your air flow restriction. I don't know how much air the engine is sucking in at red line, or how much flow DCI offer, but it's a place to start for knowing if more is needed or not, though you'd think that any DCI would have more than enough flow capacity or flow rate to feed the N54 car all the way to Redline. Does yours? Also consider that if the smaller filters have more air resistance(less flow), they won't be used until after the DCI filters have maxed their flow capacity. Air, like water, will always take the least restrictive path Last edited by Pinscher; 01-29-2019 at 05:24 PM.. |
| Bookmarks |
