Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > repairing a "polished lip"
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
Reply
      06-14-2012, 02:01 PM   #23
Br0
MFCEO
Br0's Avatar
Drives: 09' e92 335i M-Sport
Don't over complicate this OP, it's not hard. If you want it fixed take it to a wheel repair shop...it doesn't matter if it's clear coated or not they know what to do and if it's a good shop they will match the other 3 no problem, I've done it numerous times with expensive forged wheels. If you dont want to pay the 1 bill, don't get it fixed. Trying something yourself is going to lead to bad results.
      06-14-2012, 02:11 PM   #24
BlackedOutBimmer
BlackedOutBimmer's Avatar
959
Drives: 2022 BMW M4
The more I dig into this, this might be the best answer...
My car is a DD, and rims are used, If I am expecting perfect looking wheels than I am crazy - I am not, hence why I bought used. The wheels look awesome - except that that on the chrome lips on the 2 rear wheels - minimal curb rash and the black paint has no nicks or scratches in all 4 wheels. Seems almost a waste to spend $200 repairing the 2 rear wheels when I barely paid mroe than that for all 4...
I was just looking for a "cheap and quick" DIY to get the wheels new looking, not sure if I want to spend 200 bucks to have them refinished.... and where I am OK doing work myself, stripping the polish off the lips and trying to re-surface them completely seems more than I want to get involved with...
was kind of hoping for some magical mother's polish that can fill the nicks in, polish the lips, and protect the wheel...
...maybe I should just be asking how to maintain their current coniditon and not have them get worse... there is NO rust, and I want to keep it that way...
2022 G82 M4 6spd RWD
2019 G01 X3 M40I
2008 E90 328i 6spd
      06-14-2012, 02:54 PM   #25
PSUSMU
Drives: 2008 Porsche 911 Carrera S
Do it once, do it right.
Options:
1. Don't do anything (free)
2. Do it yourself
- Use aircraft stripper or sandpaper to remove the clearcoat ($10?)
- Apply new clearcoat ($10?)
3. Have a shop professionally refinish it ($100?)
Up to you. Option #3 is doing it right. Option #2 is the cheap route.
You can't go the cheap route and expect great results.
      06-15-2012, 01:58 PM   #26
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2224
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
To the OP. As everyone stated, you'll need to make sure if there's a clear coat or not. I haven't seen something like that happen to a polished lip before so it makes me think that the clear coat is bad.
If it's cleared - You can either sand it down by hand to remove the clear or use chemicals to strip it. Make sure to go in only one direction if you go with the sanding method. OR, you can use aircraft paint remover but if you're not careful, it'll strip the paint off the face of the wheel too. It's like acid that you brush/spray on and it'll start to strip the clear/paint off. Amazing stuff, extremely strong. (Careful, few seconds on the skin and it'll really give you a nasty burn so use protection :P )
If it's not cleared - Simply use some elbow grease and polish&polish. You're going to need to polish it anyway if you're going to remove the clear and this is the product I recommend:
It's not a MUST for reapplying the clear coat. Just remember that if you have bare metal, it's exposed to the air/elements and it'll slowly oxidize and not look as shiny. All you'll need to do is simply re-polish it. I hope this helps you out!
-Don
      06-15-2012, 11:32 PM   #27
BlackedOutBimmer
959
Drives: 2022 BMW M4
-Don
What about if the lips are clear coated, but it seems the "nicks" have scratched the clear off. if I rub my hand across, the nicks "indent" into the wheel... what polish can I use? I dont want to harm the lips if they are cleared.
2019 G01 X3 M40I
2008 E90 328i 6spd
      06-17-2012, 10:16 AM   #28
zeenon53
zeenon53's Avatar
57
Drives: BMW
Those aren't rock nicks, that's the cheap clear coat showing age. I had that same problem with a set of axis wheels I had a few years ago. I taped off the entire face of the wheel and used the aircraft remover, sanding with take much longer. The clear coat will instantly flake off with the aircraft remover. After you remove the clear you will have to polish the wheels at least once a month or the raw metal will start pitting very fast. I recommend stripping it off and re clearing the wheels. It will be mush easier to maintain.
2016 340i xdrive
2009 335i
      06-17-2012, 10:22 AM   #29
BlackedOutBimmer
959
Drives: 2022 BMW M4
... instead of stripping the polish that is already on it off, can you just try to "polish" the effected areas and then get a clear coat pen or something to cover them up?
2019 G01 X3 M40I
2008 E90 328i 6spd
      06-17-2012, 09:06 PM   #30
PSUSMU
No, stop trying to cheap out. We told you your options.
      06-18-2012, 12:29 AM   #31
zeenon53
zeenon53's Avatar
57
Drives: BMW
Not going to happen.
2016 340i xdrive
2009 335i
      06-18-2012, 07:09 AM   #32
BlackedOutBimmer
959
Drives: 2022 BMW M4
.... ok then what about protecting them so they don't get worse...
2019 G01 X3 M40I
2008 E90 328i 6spd
      06-18-2012, 01:36 PM   #33
VMRWheels
VMRWheels's Avatar
2224
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
There isn't much you can do to make it better. Best bet would be to strip the clear coat off and polish the metal underneath.
      06-18-2012, 01:44 PM   #34
bmw325i
Drives: 2006 BMW 325i
Can't you just wetsand the clear to remove it. I know it would take longer but you won't have to worry about messing it up. Using aircraft stripper I'd be worried about stripping the paint off the face.
Reply
