PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW 3-Series (E90 E92) Forum
All E90 OEM Wheels (images and specifications)
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
Thread Tools |
| 11-09-2011, 09:10 AM | #177 |
Rep 8
I am looking at a 5-year old V spoke OEM rims (style 285) for my 2011 335i x-drive. The question is, the offset will not likely change over the years on this style, will it?
| 12-07-2011, 06:58 PM | #178 |
Rep 93
Drives: x
193m's
I think that my 193m's look amazing, though I will be a happy man when these Bridgestone OEM run flats wear out and I can switch to something else.
| 12-22-2011, 05:16 PM | #179 |
Rep 1,169
Drives: Jattizm
Can i Mount OEM GTS ZCP M3 rims on my 2008 335i E90 with sports suspension?
My current wheels are: Type 162 (Front: 18x8 ET34 225/40 R18) (Rear: 18x8.5 ET37 255/35 R18) I want to go for: Type 359 ZCP (Front: 19x9 ET 31 245/35 R19) ( Rear: 19x10 ET25 265/30 R19) I want to do it on stock suspension without any fender roll out or spacers... Can all you experienced people help me out..? |
| 12-24-2011, 01:43 PM | #180 |
Rep 1,169
Drives: Jattizm
What is the difference between Y rated and W rated tires?
I was looking to buy michelin ps2 tires for my 2008 335i E90. Just browsing through web sites and founded 2 kind of tires 1) Michelin Tires PILOT SPORT PS2 235/35ZR19 91 Y 2) Michelin Tires PILOT SPORT PS2 235/35ZR19 87 Y Does any body knows and the difference? Thanks |
| 12-24-2011, 11:21 PM | #181 | |
Commander-In-Chief
2628
Rep 9,145
The "W" indicates a maximum speed rating of 168 mph and "Y' 186 mph. Either is beyond the capabilities of your car.
![]() Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
| 12-31-2011, 01:55 AM | #182 |
need4speed
520
Rep 1,903
Anyone know which style wheels are on the 2010 E90 335i M-sport? And are they 18 x 8.5 in back and 18 x 8 in front? Also, would 265's fit in the back on these wheels?
Thank You |
| 01-02-2012, 03:40 PM | #183 | |
Rep 7,519
Drives: 2009 E90 335i MT
I couldn't find a 255/35R18 snowtyre so had to buy an extra pair of 18x8J rims. I need to sell the 18x8.5J and the four Bridgestones to reclaim room in my garage.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
| 01-03-2012, 07:22 PM | #184 |
Rep 1,942
How much does each wheel weigh?
Former E90 325i:
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight. |
| 01-20-2012, 11:40 AM | #185 |
Rep 21
I have 156s on a 2008 328i, would going up to 20s be a big jump? or should I try 18s? Being a noob, does it matter if run equal widths all around of have a staggered set?
Only the "Don" survive
| 01-20-2012, 07:53 PM | #186 |
Rep 7,519
Halligan, you can run equal widths all around. Just make sure the offset (ET) is the same as the ones you're replacing.
| 01-28-2012, 01:36 PM | #187 |
Rep 2,072
Drives: 2010 BMW E90 330i M Sport
Hi guys,
Managed to find a used set of E92 335i 17" Style 188 narrow/wides with Bridgestone Potenza RFT's tyres. Fitted them this afternoon! ![]() ![]() ![]() ![]() ![]() ![]() Just as well I checked the tyre pressures! The left front was pumped up to something like 4.5 bar!!! All the others were sitting around 2 bar, so adjusted them to the correct pressures and initialised the tyre pressure monitor. Absolutely pleasantly surprised with how the car feels with these used tyres! Was expecting a slight pull or vibration or noise, but instead it runs smooth and true, and better than those freaking horrible Continental RFT's! Took the car along a fairly rutted road where it would usualy tramline - seemed to be immune to this with the Bridgestones! Then went onto the freeway and took her up to 140 km/h and perfectly smooth the whole time and absolutely stable! The Continentals weren't too bad on a good piece of freeway, but since they were balanced the last time and rotated, there has been a minor vibration and on harder acceleration at freeway speeds it almost felt like there was a slight shudder (ever so slight, but noticeable and of course disconcerting). So I reckon for now these tyres are perfectly fine, just don't like the difference in wear that the front tyres have, also the left front which is the more worn of the two seems to have a slightly rounded contact patch, almost as if it was not pumped up to the correct pressure and a bit too soft. All the tyres have a fair degree of shoulder feathering, and I can see that the 335i that it came off of was DRIVEN, some of the rubber on the front tyres has some tell-tail signs of sharp high speed cornering! I must say, now with this experience, it's those damn Continentals that's been the curse of my tramlining problems! |
| 03-11-2012, 02:07 PM | #188 |
Pushing Rope in the Cellar
12
Rep 83
Seventeens just look so small on my 335d since I've driven a 4runner with 33s for the last 10 years.
Anyone know what style these are? I thought they were 160, but they're not. Last edited by Col Mustard; 03-11-2012 at 02:44 PM.. |
| 03-11-2012, 03:12 PM | #189 |
Rep 7,519
Style 284
How did you get the ding in the bonnet?
| 03-11-2012, 04:12 PM | #190 |
12
Rep 83
Thanks. The former owner transported it from CA to CO. During offload, a chain fell on it. I've only had the car a few weeks, and it's on my list to fix. That and upgrade the wheels/tires.
| 03-11-2012, 10:50 PM | #191 |
Rep 7,519
Are you in Colorado or California?
| 03-13-2012, 08:11 PM | #193 |
Rep 57
Hey guys, any idea what style wheels these are? Found them nearby on craigslist and trying to pick them up for my 2007 328xi. They are 17" Look similar to 199s but they aren't 19".... you think these are not OE?
| 03-16-2012, 04:09 PM | #194 |
![]() 12
Rep 110
Drives: 2008 E90 335i
I want to keep my style 159 rims on my jet black 2008 e90, so I was wondering how they look with spacers and a lowered suspension. Does anybody happen to have pictures of what that looks like?
| 04-03-2012, 09:22 PM | #196 |
![]() ![]() ![]() ![]() 138
Rep 910
I'm a new owner, first time bimmer, so forgive me but I did not see the Style 313 listed/shown. It's a BMW Performance wheel for the E9x AFAIK. I want these -
http://www.e90post.com/forums/showthread.php?t=262392 ![]() Last edited by Kid Red; 04-18-2012 at 06:51 PM.. |
| 04-04-2012, 08:05 PM | #197 |
Rep 7,519
Nice looking wheel but I still prefer the BMW Performance Style 269 over the 313.
| 04-05-2012, 04:50 PM | #198 |
Rep 14
| Bookmarks |
