Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Jamex coilovers or H n R springs
Reply
      08-26-2010, 03:56 PM   #1
parminder
Drives: bmw e92 325i se
hi guys was looking at the coilover kits rather cheap jamex for £250 from ebay. has anyone on here ever used it on a bmw e92 or rather get a h n r springs. was gettin eitherr a 18" or 19" alloys. which will suit the best
      08-26-2010, 04:05 PM   #2
Giff
Giff's Avatar
Drives: E90
I'd be a little wary of that kit.
What do you want to achieve? If your std shocks have done less than 60k an Eibach Pro spring kit will give you a reasonable drop and certainly improve the handling.
      08-26-2010, 04:12 PM   #3
parminder
hey thnx for the reply. the shock done just bout 90k and thing is want to get either 18 or 19 but dont wanna drop it way too much need a comfortable ride instead. some good n bad reviews on jamex just wanted 2 know if anyone rea;;y used it on here.
      08-26-2010, 07:30 PM   #4
m1bjr
LSD - No, you're not seeing things
m1bjr's Avatar
United Kingdom
83
Drives: Baby F36 Gran Coupe
Never read of anyomne using that on this forum, and I have done a LOT of reading.
So that might tell you something
If you dont want the fairly big drop of H&R then as above, Eibach Pro Kit is probably worth a look.
      08-26-2010, 07:33 PM   #5
E92Fan
Moderator
E92Fan's Avatar
United Kingdom
372
Drives: .
I'd NEVER go anywhere near a Jamex suspension setup. There's a reason why good dampers cost decent money, and in my opinion you're better off staying with OEM than going for a Jamex
You want to use 18/19" wheels, want a comfortable ride, and want it lower?
Eibach Pro-Kit is the way to go if you just want a set of springs - more comfortable than the H&Rs. However your dampers might be a bit too worn to match well with the new springs. New dampers from BMW ??
Or, go for a decent matched spring/damper setup... But it will cost you a lot more than £250
      08-27-2010, 04:11 AM   #6
Vid
Vid's Avatar
United Kingdom
14
Drives: E90 330d M-sport
Sorry to jump on this, but talking about the Eibach pro-kit, does it offer any more of a drop over M-sport suspension which is already a touch lower than standard?
Thanks
      08-27-2010, 05:09 AM   #7
Yahoo
Drives: 335i e91 LCI msport
Yes - the Eibach kit is lower than the msport setup. I forget by how much, but it is lower and looks perfect imo. H&R is too low, Eibach pro-kit is bang on.
      08-27-2010, 05:24 AM   #8
Vid
Vid's Avatar
United Kingdom
14
Superb, thanks!
      08-27-2010, 05:48 AM   #9
doughboy
doughboy's Avatar
1603
Drives: 2007 E85 Z4M Roadster
I looked at the Eibach pro kit springs, and for the 335i/d Tourers it specifies a 0mm (zero) rear drop??
All other E91 models specify a rear drop except the 335i/d
Which ones did you use?
      08-27-2010, 06:34 AM   #10
Yahoo
Yes - I noticed that when I researched them. I have got the pro-kit and it definately does drop the rear end. Not as much as the front, as this is where e9x's need the drop the most, but there certainly is some movement.
      08-27-2010, 09:34 AM   #11
m1bjr
m1bjr's Avatar
United Kingdom
83
Pro Kit - 15mm front and 10mm rear drop over sport suspension apparently.
Still waiting for mine to arrive
      08-27-2010, 10:07 AM   #12
doughboy
doughboy's Avatar
1603
That'll be just nice, the Birds kit I fitted has the same drops, just right IMO.
      08-27-2010, 01:30 PM   #13
Butch
Butch's Avatar
United Kingdom
65
Drives: E90 330i SE Auto
2005 330i  [0.00]
I've been considering getting new springs eventually- either eibach pro or m sport. Eibach pro are approx £150, but I'm concerned about the ride quality.
The msport springs wouldn't be as harsh (I presume?) as they are not as low, but not sure how much oem msport springs are - anybody know the price just for parts?
BMW E90 (2005) 330i SE Auto - E90Post Stickers, Exhaust Mod, Private Plates, Debadged, 19" Style 230 wheels, Toyo Non-RFT, MFD Scoops, K&N, Black Calipers/Hubs, 35% Rear Window Tints, Black/White Roundels, BMW Splitters, Blacklines, 12mm Rear Spacers, BMWP Knob... Future Mods - Drop?
      08-27-2010, 01:48 PM   #14
Giff
Giff's Avatar
Drives: E90
Are you sure the M Sport springs are 10mm shorter or is it that their shocks have a 10mm lower perch?
      08-27-2010, 02:08 PM   #15
TikoV
Scotland
38
Drives: BMW 335d/X5 40d
I have to disagree on the H&R's. Eibachs are great but the other is no harsher on ride in my opinion. Then, there's teins if you want it dropped more but for our roads and potholes I'd advise against.
As for your original question, I personally wouldn't go for Jamex. There are other coilover kits on the market that won't cost you a kidney. Maybe worth considering if you got miles on your current suspension.
      08-27-2010, 02:32 PM   #16
doughboy
doughboy's Avatar
1603
what do you mean?
a car rests on its springs, the height is set by the rate and length of the spring.
shocks don't effect ride height.
m sport springs give a 15mm or so drop from standard. that doesn't mean the spring is is 15mm shorter as it has a different rate so we don't know how much it compresses.
      08-27-2010, 02:40 PM   #17
doughboy
doughboy's Avatar
1603
oe springs are about £80 each (£320 for 4) so a bit pricey.
remember ride quality is much more decided by dampers rather than springs. but ideally they need to be matched.
eibach will be fine i'm sure. quite a drop from se though...
      08-27-2010, 03:10 PM   #18
Yahoo
Butch - the spring rate of the Eibachs are very similar to standard msport springs.
The Eibach springs have a progressive rate, meaning that they start off similar to OEM springs (say for the first 50% of travel), then the more compressed they become the stiffer they become - this is to compensate for the reduced range of travel compared to OEM springs.
OEM springs have a linear spring rate meaning that they maintain a similar stiffness throughout the whole of their range of travel.
      08-27-2010, 04:40 PM   #19
Butch
Butch's Avatar
United Kingdom
65
2005 330i  [0.00]
That's interesting, so the ride isn't going to be really any harsher on eibachs. I have to negotiate potholes and speed bumps on a daily basis so was thinking more the msport.
Rather than buy oem, Is there a decent aftermarket manufacturer that make msport height springs?
Thanx for the info. Sorry for the thread jack.
      08-27-2010, 05:04 PM   #20
Giff
Giff's Avatar
Drives: E90
Originally Posted by doughboy View Post
what do you mean?
Spring perch, can be a different height.
For example Bilstein shocks often have a lower spring perch, fitting them with std springs will give a lower ride height.
Several other aftermarket manufacturers offer shocks with an adjustable perch to allow variation of ride height.
On reflection, if Eibach quote a 25mm drop on an SE and 15mm drop on an M Sport then it would be logical to assume that the difference is in the springs and not the shocks.
      08-28-2010, 07:22 AM   #21
doughboy
doughboy's Avatar
1603
Sorry Giff - I misunderstood you on that one.
But that would only apply to front struts, as the rear springs sit in fixed seats.
(unless you go for rear coilovers of course)
      08-28-2010, 10:25 AM   #22
parminder
so all in all i should get new shocks and eiback pro kit or just the springs which go no less than 15mm n 10mm front n rear. ive got £1000 budget which includes new 19 alloys n lowering or if swoppin my stocks is successful will consider getin fk coilovers which aint a bomp in pricing me says
Reply
